Concentrated Lateral Displacement Applied on Horizontal Frame Member Equations and Calculator
Frame Deflections with Concentrated Lateral Displacement Applied on Horizontal Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Lateral Displacement Applied on Horizontal Member Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
Δo Can be an increase in the length of member l1 or a dercrease in length of l2.
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
