Concentrated Lateral Displacement 5 on the Horizontal Deflection Equation and Calculator
Concentrated Lateral Displacement on the Horizontal Member Elastic Frame Deflection Left Vertical Member Guided Horizontally, Right End Pinned Equation and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Moment Calculator:
Since ψA = 0 and HA = 0
Note: Δo could also be an increase in the length l1 or a decrease in the length l2.
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
