Concentrated Moment Left Vertical Deflections Equation and Calculator
Frame Deflections with Concentrated Moment Applied to Left Vertical Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Moment Applied to Left Vertical Member Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
