Concentrated Moment on the Horizontal Member 3 Frame Deflections Equations and Calculator
Concentrated Moment on the Horizontal Member Elastic Frame Deflection Left Vertical Member Guided Horizontally, Right End Pinned Equation and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Moment Calculator:
Since ψA = 0 and HA = 0
General reaction and deformation expressions with right end pinned
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
