Countersink Spot Drill Depth Formula and Calculator
Countersink and Spot Drill Depth Formula and Calculator
Preview: Countersink and Spot Drill Depth Calculator
The following formulas are for countersinks and spot drills that have been sharpened to a point, allowances on tool depth will have to be made if the countersink or spot drill is not sharpened to a point.
For countersinks and spot drills that have been sharpened to a point
To find the tool travel “Z” required for any sharp-point countersink or spot drill angle, use either of the following formulas:
Z = ( D / 2 ) [ 1 / tan ( α / 2) ]
or
Z = ( D / 2 ) cot ( α / 2)
α = countersink angle
D = countersink diameter
Z = depth of tool travel required from surface of part
To find the tool travel “Z−a” required for any truncated countersink or spot drill angle, use either of the following formulas:
Z - a = ( D - T ) / 2 · [ 1 / tan ( α / 2 ) ]
Z - a = ( D - T ) / 2 · cot ( α / 2 )
a = allowance for truncated countersink tool
d = diameter of through hole
T = diameter of small end of truncated tool
The table below is a quick reference for some predefined To calculate the tool travel “Z”, multiply the factor by the countersink diameter.
Countersink Angle α, degrees |
Factor (Imperial or Metric Units) |
Factor Imperial or Metric Units) |
60 |
0.866 |
118 |
0.3004 |
82 |
0.5752 |
120 |
0.2887 |
90 |
0.5000 |
135 |
0.2071 |
100 |
0.4195 |
142 |
0.1722 |
