Critical Pressure and Temperature Cavett Correlation Calculation
Heat Transfer
Engineering
Thermodynamics
Resources
Fluids
Engineering and Design Data
Critical Pressure and Temperature Cavett Correlation for Oil Formula and Calculator
Related (Basic Membership Min Required):
New Correlation for Calculating Critical Pressure of Petroleum Fractions
Preview: Critical Pressure and Temperature Cavett Relation Calculator
Critical Pressure Cavett Relation Formula
Pc = 10(2.829) + ( 0.0009112 · Tb ) - ( 0.0000030175 · Tb2 ) + (0.0000000015141 · Tb3) - ( 0.000020876 · Tb · API ) + (0.000000011048 · Tb2 · API ) + ( 0.0000000001395 · Tb)2 · API
Critical Temperature Cavett Method Formula
Tc = 768.071 + ( 1.7134 · Tb ) - ( 0.0010834 · Tb2 ) + (0,0000003889 · Tb3) - ( 0,00089213 · Tb · API ) + (0,00000053095 · Tb2 · API ) + ( 0,000000032712 · Tb2 · API2 )
Tb = Boiling Point Temperature (°F)
API = API Gravity of oil (API)
Pc
Critical Pressure (Psi)
Tc = Critical Temperature (°F)
Crude oil is classified as light, medium, or heavy according to its measured API gravity.
Light crude oil has
an API gravity higher than 31.1° (i.e., less than 870 kg/m3)
Medium oil has an
API gravity between 22.3 and 31.1° (i.e., 870 to 920 kg/m3)
Heavy crude oil has an API gravity below 22.3° (i.e., 920 to 1000 kg/m3)
Extra heavy oil has an API gravity below 10.0° (i.e., greater than 1000 kg/m3)
Wikipedia
- API Casing 4.500 - 5.000 Dia. Engineering Data Table Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter
- API Gravity Gravity Equations and Calculator
- Fluid Characteristics Chart Table | Fluids Data, Fluids Density | Vapor Pressure | Kinematic Viscosity
- Pressure - Temperature Ratings for Pipe Flanges, and Flanged Fittings from ANSI B16.5-1981
- API Separator Sizing Macro-Enabled Excel Spreadsheet Calculator
- API Process Pump Review
- API 570 & 510 Calculations
- API NUE Tubing Recommended Torque Table
- Fluids Dynamic Simulator and stress reliever
- Oil Classifications Diesel and Gasoline Engines
- Critical Scuffing Temperature for Gears | Gear Operating Temperature
- API Tubing Engineering Table Chart
