Dams Spillway Flow Calculator
Fluids Engineering and Design
Civil Engineering and Design
Dam’s Spillway (overflow spillway) Flow Formula and Calculator
A dam’s spillway (overflow spillway) is designed for a capacity based on the dam’s inflow hydrograph, turbine capacity, and storage capacity. Spillways frequently have a cross section known as an ogee, which closely approximates the underside of a nappe from a sharpcrested weir. This cross section minimizes the cavitation that is likely to occur if the water surface breaks contact with the spillway due to upstream heads that are higher than designed for.
Premium Membership Calculator
Discharge from an overflow spillway is derived in the same manner as for a weir. Equation 1 can be used for broad-crested weirs (C1 = 0.5–0.57) and ogee spillways (C1 = 0.60–0.75).
Eq. 1,
Q = 2/3 C1 b (2g)0.5 H3/2
H = height, m
b =
width of weir, m
Q = Flow, m3/s
g = gravity, 9.81 m/s2
C1 = discharge coefficient
- Civil Engineering Reference Manual, Fifteeth Edition
- Trapezoidal Weirs Flow Formula and Calculator
- Triangular Weirs Flow Formula and Calculator
- Water Flow Over Rectangular Weir Formula and Calculator
- Weir Flow Rectangular Open Channel Water Flow Calculator and Formula
- Water Flow Kinetic Force in Flow Around Submerged Object Calculator and Equation.
- Partially Full Pipe Flow Calculator Determines the Flow within a partially full pipe using the Manning equation.
- Pipe Flow with Gradual Size Enlargement Formula and Calculator
- Barlow's Formula, Calculator and MAOP Design Factors Barlow's formula is used to verify that pipe used for gathering, transmission, and distribution lines can safely withstand operating pressures.
- Chézy and Manning's Equation Manning's equation, which is based on Chezy's equation, is method to calculate the free surface flow within a channel.
- Fluid Flow Open Channel Calculator Chezy and Manning's equation to determine the wetted perimeter, hydraulic radius, flow area, Chezy coefficient and flow velocity
- Hazen-Williams Method for Pipe Friction and Pressure Drop Hazen-Williams formula:
- Draining Time for Horizontal Tank Formulas and Calculator
- Draining Time for Vertical Tank Formulas and Calculator
- Draining Time for Spherical (Sphere) Tank Formulas and Calculator
- Hooghoudt's Drainage Rate Equation and Calculator
- Rainfall Runoff Rate Formulas and Calculator
- Design Rainfall Intensity and Peak Storm Water Runoff Rate Equations and Calculator
- Storm Drain Pipe Size Requirement Formula and Calculator
