Distributed Load Elastic Frame Deflection Left Vertical Member Guided Horizontally Equation and Calculator
Distributed Load Elastic Frame Deflection Left Vertical Member Guided Horizontally, Right End Pinned Equation and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Load Calculator:
Since ψA = 0 and HA = 0
General reaction and deformation expressions with right end pinned
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
