Elastic Frame Ends Fixed Case 5b Roarks Formulas for Stress and Strain Equations and Calculator
Reaction and deflection formulas for in-plane loading of elastic frame with mounting ends fixed and distributed load on the horizontal member Case 5b formulas and calculator:
Loading Configuration
Deformation equations:
Loading terms for distributed load on the horizontal member frame member:
Where used:
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
Roark's Formulas for Stress and Strain, Seventh Edition, Table 8.2 reference loading number 5b
