Elastic Frame Ends Fixed Case 5e Roarks Formulas for Stress and Strain Equations and Calculator
Reaction and deflection formulas for in-plane loading of elastic frame with mounting ends fixed and concentrated lateral displacement on the horizontal member formulas and calculator. Roark's Formulas for Stress and Strain, Seventh Edition, Table 8.2 reference loading number 5e
Loading Configuration
Deformation equations:
Loading terms for concentrated lateral displacement on the horizontal member frame member:
Where used:
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
