Elongated Section Torque Applied Equation and Calculator
Torsion Applied Deformation and Stress of any elongated section with axis of symmetry OX; Equations and Calculator
Preview
Torsion Applied Deformation and Stress of any elongated section with axis of symmetry Calculator
θ = ( T L ) / ( K G )
Shear Stress Maximum
For all solid sections of irregular form the maximum shear stress occurs at or very near one of the points where the largest inscribed circle touches the boundary,* and of these, at the one where the curvature of the boundary is algebraically least. (Convexity represents positive and concavity negative curvature of the boundary.) At a point where the curvature is positive (boundary of section straight or convex) this maximum stress is given approximately by:
* Unless at some point on the boundary there is a sharp reentant angle, causing high local stress.
θ = angle of twist (radians),
α = degrees,
L = Length (in, mm),
D = Diameter of largest inscribed circle (in, mm),
Ix = moment of inertia about axis of symmetry (in4, mm4),
U = Center Line Length (in, mm),
