Equilateral Triangle Flat Plate Stress and Deflection Equation and Calculator
Equilateral triangle; all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator.
Preview: Parallelogram plate uniform loading over entire plate Stress and Deflection Calculator
Equilateral Triangle Plate
Uniform Loading Over Entire Plate ![]() |
Stress at x = 0, z = -0.062a
Stress at x = 0, z = 0.129a
Deflection at x = 0, z = 0
q = Applied load (force) (lbs/in2)
E = Modulus of Elasticity (lb/in2)
a = Width of plate (in)
σ = stress, (lbs/in2)
y = Deflection (in)
