Fatigue SN Curve Python Script Application
This applications is python-based to perform calculations to graph a S-N curve.
An S-N curve defines the number of cycles to failure, N ( S ) , when a material is repeatedly cycled through a given stress range S. The S-N curve can be used to calculate the damage in a fatigue analysis.
NOTE:
Refunds are not awarded after Python files have been downloaded - review your membership agreement for details.
​Units (if utilized) utilized within calculators are either SI or Imperial (some enable both SI and Imperial) and member (you) are responsible for conversions. Ensure that you verify units utilized in excel application meet your requirements before downloading.
Download: Fatigue SN Curve Python Script Application
Inputs required
1) Get material Properties (Sut, E, Poisson)
2) check de example
3) Run the code
Output
Excel file created:
Steel csv
Source
Support:
  • Engineers Edge has tested the basic functions and operation of this application using Python 3.11.9 and supporting modules.
  • Supporting Windows application "Visual Studio Code".
  • THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
