Minimum Length of Thread Engagement Calculator Per FED-STD-H28/2B
Engineering Metals and Materials | Strength of Materials
For equations and illustrative graphics see:
All units shall be consistant and given in inches.
- Length of Screw Thread Engagement per. ISO 965-1 Calculator , Formula and Table Length of engagement of mating threads is selected to utilize full tensile strength of a bolt prior to shearing and nut threads.
- Bolt Elongation Formula and Calculator per. ASME PCC-1 When bolt elongation (bolt stretch) measurement is selected as the load-control technique to be used, the required bolt elongation is computed according to the following equation
- Bolt Elongation Stress Formulas and Calculator per. MIL-HDBH-60 Micrometer Bolt Elongation Method: Below the proportional limit. bolt elongation is directly proportional to axial stress, i.e., elongation increases in the same proportion as stress increases.
- Engineering Fundamentals of Threaded Fastener Design and Analysis - Premium Membership Required
- Bolt Elongation Equation and Calculator while under Axial Stress
- Fastener / Thread Tensile Area of External Thread Formula
- Force Required to Strip the Bolt Threads Formula and Calculator
- ISO Stress Area Equation and Calculator - Proof load values are given in BS EN 20898-2:
- Torque Clamp Force Calculator
- Stud Preload Calculator
- Loading Capacities of Ordinary Bolts per. BS449: Part 2 Bolt Grade 6.8
- Loading Capacities of Ordinary Bolts per. BS449: Part 2 Bolt Grade 8.8
