Fifth Wheel Coupling Loading Equations and Calculators
Machine and Mechanics Design Equations and Calculators
Fifth Wheel Coupling Loading Equations and Calculators.
The required fifth-wheel coupling size is determined by the D value.
D value for fifth-wheel coupling equation:
D = ( 0.6 · G · T · U ) / ( T + R - U )
Permissible gross weight of the semi trailer equation:
R = ( D · (T · U ) / ( ( 0.6 · G · T ) · D )
If the permissible gross weight of the semi trailer and the D value of the fifth-wheel coupling are specified, the permissible gross weight of the trailer unit can be calculated with the following formula:
Permissible gross weight of the tractor unit equation:
T = ( ( D · ( R - U ) ) / ( ( 0.6 · G · R ) - D )
If the fifth-wheel load is sought and all other loads are known, the following formula can be used:
Formula for fifth-wheel load equation:
U = T + R - ( 0.6 · G · T · R ) / D
D = D value, in kN
R = Permissible gross weight of the semi trailer unit in metric tons, including the fifth-wheel load
T = Permissible gross weight of the tractor unit in metric tons, including the fifth-wheel load
U = Fifth-wheel load, in metric tons
G = Gravity, 9.81 m/s2
