Finite Element Analysis Framework Python Application Script
Applications & Design
This applications is a python-based finite element analysis framework for education and research purpose by Dr. Pei Yaoyao at the sponsor of Hubei Univeristy of Technology!
NOTE:
Refunds are not awarded after Python files have been downloaded - review your membership agreement for details.
​Units (if utilized) utilized within calculators are either SI or Imperial (some enable both SI and Imperial) and member (you) are responsible for conversions. Ensure that you verify units utilized in excel application meet your requirements before downloading.
Download: Numerical Analysis of Fluids Application
 Elements supported
  • Spring1D11
  • Spring2D11
  • Spring3D11
  • Link1D11
  • Link2D11
  • Link3D11
  • Beam1D11
  • Beam2D11
  • Beam3D11
  • Tri2d11S---- Triange elements for plane stress problem
  • Tri2D11 ---- Triange elements for plane strain problem
  • Tetra3D11
  • Quad2D11S
  • Quad2D11
  • Plate3D11 ---Midline plate
  • Brick3D11
We name the elements with "Name" + "dimension" + 'order" + "type", type 1 means elastic .
Truss
Truss
Frame with Hinged Node
Embedded Wall Design
Fluid flow problem
Fluid flow problem
Python Module Requirements
numpy
scipy
matplotlib
numpydoc
sphinx==6.2.1
sphinx-autoapi
sphinx-copybutton
sphinx-gallery
sphinx-book-theme
esbonio
Mpmath
Source
References
  • Tiitinen, Hinkkanen, Harnefors, “Stable and passive observer-based V/Hz control for induction motors,” Proc. IEEE ECCE, Detroit, MI, Oct. 2022
  • Tiitinen, Hinkkanen, Kukkola, Routimo, Pellegrino, Harnefors, “Stable and passive observer-based V/Hz control for synchronous Motors,” Proc. IEEE ECCE, Detroit, MI, Oct. 2022
  • Pellegrino, Armando, Guglielmi, “Direct flux field-oriented control of IPM drives with variable DC link in the field-weakening region,” IEEE Trans.Ind. Appl., 2009
  • Awan, Hinkkanen, Bojoi, Pellegrino, “Stator-flux-oriented control of synchronous motors: A systematic design procedure,” IEEE Trans. Ind. Appl., 2019
  • Kim, Ha, Sul, “PWM switching frequency signal injection sensorless method in IPMSM,” IEEE Trans. Ind. Appl., 2012
Support:
  • Engineers Edge has tested the basic functions and operation of this application using Python 3.11.9 and supporting modules.
  • Supporting Windows application "Visual Studio Code".
  • THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
