Flow Velocity in Straight Sewers Formula and Calculator
Civil Engineering and Design
Obstruction-free straight sewers will have a flow velocity of
Formula 1.0,
V = ( C / n ) · ( R2/3 · S1/2 )
V = Flow velocity ft/s
n = coefficient dependent on roughness of conduit surface
R = A / P - hydraulic radius, ft = area in ft2, of fluid divided by wetted perimeter, ft
S = energy loss, ft/ft of conduit length; approximately the slope of the conduit invert for uniform flow
C = 1.486 (conversion factor to account for change from metric units used in development of the formula)
The value of n can range from 0.013 in smooth concrete sewers to 0.02 in plain pipe. Further, n usually increases as a sewer pipe ages. Specific n values are given in engineering handbooks such as those cited in the references section of this webpage.
The water flow, cu ft/s is:
Q = A · V
where:
A = cross-sectional area of flow, ft2.
- Storm Drain Pipe Size Requirement Formula and Calculator
- Rainfall Runoff Rate Formulas and Calculator
- Pipe Roughness Coefficients Table Charts | Hazen-Williams Coefficient | Manning Factor
- Darci's Equation Fluids Flow Equation
- Head Loss Darcy - Weisback Equation
- Head Loss Darcy Calculator - Weisback Equation
- Fluid Flow Regimes Review
- Orifice Plate Flow Calculations and Design
- Pressure Drop Along Pipe Length - Fluid Flow Hydraulic and Pneumatic
- Function for open channel flow rate with input variable for inflow
- Hicks - Handbook of Civil Engineering Calculations,
- McGraw-Hill.
- Kevin D. Wills, M.S.E., P.E., Consulting Engineer.
