Force to Press Together Hub and Shaft Design Equations and Calculator
Strength and Mechanics of Materials Menu
Interference Fit Force Required the Press Together Hub and Shaft Equations and Calculator
The axial force necessary to press shaft into hub under an interface pressure pc
Fa = π dc l µ pc
where
µ = coefficient of friction
µ = 0:085 to 0.125 for unlubricated surface
µ = 0.05 with special lubricants
The approximate value of axial force to press steel shaft into cast-iron hub with an interference SI Units
Eq. 2a
F = ( 4,137 x 104 ) [ ( do + 0.3 dc ) l δ ] / ( do + 6.33 dc)
where do , dc, l and δ in m, and F in N
The approximate value of axial force to press steel shaft into cast-iron hub with an interference USCS Units
Eq. 2b
F = 6,000 [ ( do + 0.3 dc ) l δ ] / ( do + 6.33 dc)
where do , dc, l and δ in in, and F in tonf
The approximate value of axial force to press steel shaft in steel hub SI
Eq. 3a
F = ( 28.41 x x 104 ) [ ( do2 + 0.3 dc2 ) l δ ] / do2
The approximate value of axial force to press steel shaft in steel hub USCS
Eq. 3b
F = ( 4,120 ) [ ( do2 + 0.3 dc2 ) l δ ] / do2
where do , dc, l and δ in in., and F in tonf
The transmitted torque by a press fit or shrink fit without slipping between the hub and shaft
Eq. 4
Mt = π dc2 l µ pc / 2
where
µ = 0:10 for press fit
µ = 0:125 for shrink fits
The temperature t2 in °C to which the shaft or shrink link must be heated before assembly
Eq. 5
t2 ≥ ( 2 δ / ( α dc ) + t1 )
where
t1 = temperature of hub or larger part to which shaft or shrink link to be shrunk on, °C
Mt = torque or twisting moment, Nm (lbf in)
do = hub diameter, m (in)
dc = contact surface diameter, compressive, m (in)
pc = contact pressure MPa (psi)
δ = total change in diameter (interference), m (in)
α = coefficient of linear thermal expansion, (m/m) / °C [(in/in)/°F]
Conversion
1 newton is equal to 0.00010197162129779283 tonf.
1 tonf = .00950965 N
1 tonf = 2,204.623 lbf
- Diameter Change on Press and Shrink Fit Formulae and Calculator
- Press Fit Engineering and Design Calculator
- Bushing and Plain Bearings Press or Shrink Fit Design and Application
- Cylinder Feature Press Fit Design Equations
- Dowel Pin Installation Design Tolerance Table Chart
- Design for Dowel Pin Press Fit
- Plastic (Polymer) Post and Hub Press Fit Equation and Calculator
- Interference Pressure Mechanical Tolerances Variability Equations and Calculator
- Class V Locational Interference Tolerance Chart for Holes and Bolts
- Preferred Force Shrink Fits Chart ANSI B4.1 Calculator
Machine Design Handbook 2nd Edition, 2001
Prof. Dr. K. Lingaiah
Former Principal, Professor and Head, Department of Mechanical Engineering
University Visvesvaraya College of Engineering, Bangalore University, Bangalore
