Soil Foundary Spring Calculator
Civil Engineering Design Resources
Mat Boundary Spring Generator
INPUT DATA & DESIGN SUMMARY
FOUNDATION LENGTH L = ft
FOUNDATION WIDTH B = ft
GRID TRIBUTARY AREA A = ft2
MODULUS OF SUBGRADE K1 = lb / in3
(Obtained from the soil report?? for 1' x 1' sf plate load test,
???? in the absence of a soil report obtain from table below )
  INSIDE SPRING VALUE   kips / joint
  EDGE SPRING VALUE   kips / joint
  CORNER SPRING VALUE   kips / joint
ANALYSIS
        ( for B = L )
        ( for B < L )
          = lb / in3?????? =
          =   lb / in3?????? =
      TYPICAL VALUES OF MODULUS OF SUBGRADE REACTIONS,???? K1???? (lb / in3 )
                      MOISTURE CONTENT
    TYPE OF MATERIAL     ??1 to 4%   ??5 to 8%   ??9 to 12%   ??13 to 16% ??17 to 20% ??21 to 24% ??25 to 28% ??> 28%
  Silts and clays (liquid limit >50)     -   175   150   125   100   75   50   25
  ??(OH, CH, MH )
  Silts and clays (liquid limit <50)   -   200   175   150   125   100   75   50
  ??(OL, CL, ML )
  Silty and clay sands     300   250   225   200   150   -   -   -
  ??(SM & SH )
  Gravelly sands     Over 300???????????? 300   250   -   -   -   -   -
  ??(SW & SP )
  Silty and clayey gravels     Over 300???????????? Over 300???????? ?? 300   -   -   -   -   -
  ??(GM & GC )
  Gravel and sand     Over 300???????????? Over 300???????? ?? -   -   -   -   -   -
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
