Frame Deflections Concentrated Angular Displacement on Horizontal Member Equations and Calculator
Frame Deflections with Concentrated Angular Displacement Applied on Horizontal Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Angular Displacement Applied on Horizontal Member Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
LPH
LPM
θo = Angular Displacement (radians)
W = Load or Force (lbsf, N),
