Frame Deflections Concentrated Lateral Displacement Applied Right Vertical Member Equations and Calculator
Frame Deflections with Concentrated Lateral Displacement Applied Right Vertical Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Lateral Displacement Applied Applied to Right Vertical Member Calculator:
General reaction and deformation expressions with right  and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
LPh = Δo ( -1 ); Δo can also be an increase in length l3.
LPm = 0
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
