Frame Deflections Concentrated Moment Applied to Right Vertical Member Equations and Calculator
Frame Deflections with Concentrated Moment Applied to Right Vertical Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Moment Applied to Right Vertical Member Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
