Frame Deflections Left Vertical member guided horizontally, right end pinned equations and calculator
Frame Deflections with Concentrated Load on the Horizontal Member Equations and Calculator. Left vertical member guided horizontally, right end pinned.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Load Calculator:
Since ψA = 0 and HA = 0
MA = LPM / AMM
δHA = AHM MA - LPH
General reaction and deformation expressions with right end pinned
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
