International Standard Atmosphere Data
The following table calculator give the international standard atmosphere vs altitude from sea level 0 m to 1,000,000 m.
The notation 1.79. - 5 signifies 1.79 x 10-5
Extracted from U.S. Standard Atmosphere, 1976, National Oceanic and Atmospheric Administration, National Aeronautics and Space Administration and the U.S. Air Force, Washington, 1976.
- Standard Atmospheric Data for Altitude and Temperature for U.S
- Properties atmosphere at high altitude
- Speed of Sound Table Chart
- United States Standard Atmosphere Excel Spreadsheet Calculator
- Humidity Ratio of Air Humidity ratio W is the ratio of the mass of water vapor to the mass of dry air:
- Relative Humidity Calculator and Equation
- Thermodynamic Applications Professor J. E. Emswiler of the University of Michigan
- Treatise on Thermodynamics Dr. Max Planck - Premium Membership Required
- Properties of Air Ideal Gas
- Mass and Weight
- Effects of Pressure Changes on Fluid Properties
- Effects of Temperature Changes on Fluid Properties
- Thermodynamic properties of Selected Solids at 77° F
- Saturated and Superheated Vapors
- Constant Pressure Heat Addition
- Critical Point
- Potential Energy
- Kinetic Energy
- Specific Internal Energy
- Specific P-V Energy
- Specific Enthalpy
