K-Series Joist Deflection and Stress Analysis Calculator
K-SERIES JOIST ANALYSIS
For Uniformly Loaded, Open-Web Steel Joists
Using Steel Joist Institute (SJI) Standard Load Tables
K-Series Joists Specifications
- Designations: 8K1 to 30K12
- Depths: 8 to 30 in.
- Standard Seat Depth (Height): 2.5 in.
- Span Range: 8 to 60 ft.
- ASD Load Range: 127 to 550 plf
- LRFD Load Range: 190 to 825 plf
- Maximum Span/Depth Ratio: 24
Notes:
1. OSHA is interpreting Section 29CFR-1926.751(c)2 to mean all joists whose length
>= 40' require bolted diagonal bridging in place before slackening of hoisting lines.
2. For point loads on K-series joists, the magnitude and location of load should be
indicated on the design drawings and "SP" must be added to the joist designation.
