loading Uniformly decreasing to 1/3 b Deflection Equation and Calculator. Per. Roarks Formulas
Flat Rectangular Plate; one edge fixed, opposite edge free, remaining edges simply supported loading Uniformly decreasing from fixed edge to zero at 1/3 b Stress and Deflection Equation and Calculator.
Rectangular plate; one edge fixed, opposite edge free, remaining edges simply supported loading Uniformly decreasing from fixed edge to zero at 1/3 b.
Preview: Flat Rectangular Plate Uniform Force over Entire Plate Two Long Edges Fixed, Two Short Edges Simply Supported Calculator
opposite edge free,
remaining edges simply supported.
from fixed edge
to zero at 2/3 b.
Uniformly decreasingfrom fixed edge to zero at 2/3 b.
Stress Maximum at center of fixed edge:
Stress Maximum and R = γqb
Symbols used:
q = Applied Load or Force to Flat Area of Plate (N/m2, lbs/2)
v = Poisson’s ratio (assumed to be 0.2)
t = plate thickness, (m, in)
a = plate length, (m, in)
b = plate width, (m, in)
σ = stress, (N/m2, lbs/in2)
R = Reaction force per unit length (N/m, lbs/in) normal to the plate surface exerted by the boundary support on the edge of the plate.
β = Constant From Table A
γ = Constant From Table A
Table A
a/b
0.25
0.50
0.75
1.0
1.5
2.0
3.0
β
0.023
0.048
0.061
0.073
0.088
0.097
0.105
γ
0.115
0.149
0.159
0.164
0.167
0.168
0.168
