Low Pressure Flow Oliphant and Spitzglass Formula and Calculator
Gas gathering often involves operating pressures below 100 psi. Some systems flow under vacuum conditions. For these low pressure conditions, equations have been developed that give a better fit than the Weymouth or Panhandle equations. Two such formulas are Oliphant and Spitzglass:
The Oliphant Formula for gas flow between vacuum and 100 psi:
Eq 1
Q = 42 (24) ( d2.5 + d3 / 30 ) ( 14.4 / Pb ) ( Tb / 520 ) [ ( 0.6 / S ) ( 520 / T ) ( ( P12 - P22 ) / Lm ]0.5
The Spitzglass Formula for gas flow below 1 psig at 60° F:
Eq 2
Q = (24) (3,550) [ ( 27.69
( P1 - P2 ) d5 / ( S L ( 1 + 3.6 / d + 0.03 d ) ]0.5
Q = flow rate of gas, cubic feet per day at base conditions
d = internal diameter of pipe, in.
Tb = base absolute temperature, °R (ANSI 2530 specification:
Tb = 520°R)
T =
absolute temperature of flowing gas, °R
Pb = base absolute pressure, psia (ANSI 2530 specification:
Pb = 14.73 psia) longitudinal weld joint factor from ANSI B31.3,
P1 = inlet pressure, psia
P2 = outlet pressure, psia
S = specific gravity of flowing gas (air = 1.0)
Lm = length of pipe line, miles
L =
length of pipe line, feet
- Transmission Gas Line Isothermal Flow Equations and Calculator
- Fluids Discharge Measurement Structures and Systems , Basic Principles of Fluid Flow as Applied to Measuring Systems
- Flow of Water in Pipes Equations and Calculator
- Flow Rate of Steam in Schedule 40 Pipe Tables
- Pressure Drop and Flow Rate Calculations based on the Karman Method Excel Calculator Spreadsheet
- Pressure Losses for Fluid Flow in 90° Pipe Bends
- Pressure Distribution of a Fluid within a Vessel Equations and Calculator
- Gas Processors Suppliers Association, FPS Version Engineering Data Book, 2004
- F.N. Oliphant, “Production of Natural Gas,” Report of USGS, 1902.
- “Steady Flow in Gas Pipelines,” American Gas Association, IGT Technical Report 10, Chicago, 1965.
