Parallelogram Plate Uniform Loading Stress and Deflection Equation and Calculator
Parallelogram plate (skew slab) all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator.
Preview: Parallelogram plate uniform loading over entire plate Stress and Deflection Calculator
Parallelogram Plate
Uniform Loading Over Entire Plate ![]() |
Stress at Center Plate
Deflection at the Corner:
Applicable at a/b = 2.0
θ
0°
30°
45°
60°
75°
β
0.585
0.570
0.539
0.463
0.201
α
0.119
0.118
0.108
0.092
0.011
q = Applied load (force) (lbs/in2)
β = Table data for a/b = 2.0
α = Table data for a/b = 2.0
E = Modulus of Elasticity (lb/in2)
a = Width of plate (in)
b = Height of plate (in)
σmax = stress, (lbs/in2)
ymax = Deflection (in)
