Phase Transition Data for 100 Fluids
Phase Transition and other Data for 100 Fluids.
The table calculator below gives the critical data for various gases; also the boiling temperature Tb corresponding to atmospheric pressure. The study of the critical region is becoming a specialized topic. NBS Misc. Publ. 273, 1966, contains 33 papers on phenomena near critical points.
M = molecular weight
Tm = normal melting temperature>
Δhfus = enthalpy (or latent heat) of fusion
Tb = normal boiling point temperature
hvap = enthalpy (or latent heat) of vaporization
Tc = critical temperature
Pc =critical pressure
vc = critical volume
Zc = critical compresibility factor
Prepared by the author and abstracted from Rohsenow et al., ‘‘Handbook of Heat Transfer Fundamentals,’’ McGraw-Hill.
- Properties of Pure Substances , Phase Changes Class 5
- Thermodynamics of Multiphase Closed Systems, Class 6
- Steady Flow Gas Power Cycles, Brayton Cycle, Class 11
- Steady Flow Vapor Power Cycles, Rankine Cycle Class, 12
- Steady Flow Vapor Power Cycle, Rankine Cycle with Open Feedwater Heating Class, 13
- Steady Flow Vapor-Compression Refrigeration Cycle, Class 14
- Psychrometric Analysis and Air Conditioning, Class 15
- Saturated and Superheated Vapors
- Constant Pressure Heat Addition
- Properties of the atmosphere at high altitude
- Properties of air at 1 atm pressure
- Specific Heats of Various Gases
- Specific Heat Common Gases
- Thermodynamic Properties of Saturated R-410a Tables for Temperatures -°60 to °71.3 C Enthalpy and Entropy .
- Superheated R-410a Thermodynamic Properties Tables for Temperatures -°60 to °71.3 C
- Superheated R-410a Thermodynamic Properties Tables for Pressure 300 kPa, 400 kPa, 500 kPa, and 600 kPa.
- Superheated R-410a Thermodynamic Properties Tables for Pressure 800 kPa, 1000 kPa, 1200 kPa, and 1400 kPa .
- Superheated R-410a Thermodynamic Properties Tables for Pressure 1800 kPa, 2000 kPa, 3000 kPa, and 4000 kPa
- R-134a Thermodynamic Properties Tables for Temperatures -70 °C to 101.2 °C
- Saturated R-134a Thermodynamic Properties Tables Enthalpy, kJ/kb and Entropy, kJ/k-K
- Superheated R-134a Thermodynamic Properties Tables for Pressures 50 kPa, 100 kPa, 150 kPa, and 200 kPa.
- Superheated R-134a Thermodynamic Properties Tables for Pressures 300 kPa, 400 kPa, 500 kPa, and 600 kPa.
- Superheated R-134a Thermodynamic Properties Tables for Pressure s 800 kPa, 1000 kPa, 1200 kPa, and 1400 kPa.
- Critical Point
- Potential Energy
- Kinetic Energy
- Specific Internal Energy
- Specific P-V Energy
- Specific Enthalpy
