Pipe Support Spacing For Deflection Control Design Calculator
The purpose of pipe supports is to control the weight effects of the piping system, as well as loads caused by pressure thrust, vibration, wind, earthquake, shock, and thermal displacement. The weight effects to be considered for support design shall be the greater of operating, (including thermal expansion loads) or hydrotest loads.
Preview Pipe Support Spacing For Deflection Calculator
Pipe support spacing is an important consideration in the design of piping systems. The permissible mid-span deflection concept, "y", is one technique commonly employed for support spacing. This technique is based on a specified mid-span "y" deflection of the supported pipe considering the pipe, contents, and insulation weights. The equation for determining the distance (L) between pipe supports is:
L = [ ( y · E · I ) / ( 17.1 · W ) ]¼
I = π / 64 · ( Do4 - Di4 )
Eq. 3
W = Wp + Wf + Wa
L = pipe support spacing, feet
y = permissible mid-span deflection, in
E = modulus of elasticity at design temperature
I = moment of inertia of pipe
W = weight of supported pipe, including pipe, contents, insulation, lb/ft.
Wp = weight of pipe, lb/ft.
Wf = weight of fluid within pipe, lb/ft.
Wa = weight of additional materials associated with pipe installtion, lb/ft.
Do = pipe outside diameter, in
Di = pipe inside diameter, in
17.1 = converstion + FOS
ASTM B31.3: Process Piping, ASME Code for Pressure Piping, American Society of Mechanical Engineers
- Pipe Support Hanger Spacing and Pipe Wall Thickness
- Beam Deflection Calculator and Beam Stress Formulas and Calculator
- Standard Size Steel Pipe Weights Calculator and Supporting Equations
- Steel Pipe Clamps Stress and Friction Capacity Analysis
- API Tubing Engineering Table Chart API Tubing Engineering Table Chart
- API Tubing Grade & Specifications The following guidelines apply to the use of API tubing grades.
- API Casing 4.500 - 5.000 Dia. Engineering Data Table Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter
- Schedule 40 Steel Pipe Sizes & Dimensions ANSI American National Standard Schedule 40 Welded and Seamless Steel Pipe.
- Schedule 80 Steel Pipe Sizes & Dimensions ANSI American National Standard Schedule 80 Welded and Seamless Steel Pipe.
- Stainless Steel Pipe per. ASTM A312 and ANSI B36.19
