Plastic Helical Gears Design Hp, Operating Stress Equations and Calculator
Plastics Engineering and Design
Plastic Helical Gears Rated Design Hp, Operating Stress Equations and Calculator
Preview Plastic Helical Gears Rated Design Hp, Calculator
Internal and External Helical Gears Rated Hp in US Customary Units
HP = ( Ss F Y V ) / ( ( 423 ( 78 + V1/2 ) Pn Cs )
Internal and External Helical Gears Rated Hp in Metric Units
KW = ( F Y m Ss V ) / ( 179 ( 5.56 + V1/2 ) Cs )
Operating Stress Ss in US Customary Units Internal and External Helical Gears
Ss = [ HP ( 423 ( 78 + V1/2 ) Pn Cs ) ] / ( F Y V )
Operating Stress Ss in Metric Units Internal and External Helical Gears
Ss = [ KW ( 179 ( 5.56 + V1/2 ) Cs ) ] / ( F Y m V )
Ss = safe stress in bending (lbs/in2, (from Table 2);
F = face width in inches (mm);
Y = tooth form factor (from Table 1);
m = module, (mm); = Ref. Dia / No. teeth
C = pitch cone distance in inches (mm);
Cs = service factor (from Table 3);
P = diametral pitch in inches (mm);
Pn = normal diametral pitch in inches (mm);
V = velocity at pitch circle diameter in ft/min (m/s).
V = ( rpm π D ) / 12 = ft/min
Table 1 Tooth Form Factors Y for Plastic Gears
Number
of Teeth |
14 - 1⁄2° Involute
or Cycloidal |
20° Full Depth
Involute |
20° Stub Tooth
Involute |
20° Internal
Full Depth |
Pinion
Gear
12
0.210
0.245
0.311
0.327
13
0.220
0.261
0.324
0.327
14
0.226
0.276
0.339
0.330
15
0.236
0.289
0.348
0.330
16
0.242
0.259
0.361
0.333
17
0.251
0.302
0.367
0.342
18
0.261
0.308
0.377
0.349
19
0.273
0.314
0.386
0.358
20
0.283
0.320
0.393
0.364
21
0.289
0.327
0.399
0.371
22
0.292
0.330
0.405
0.374
24
0.298
0.336
0.415
0.383
26
0.307
0.346
0.424
0.393
28
0.314
0.352
0.430
0.399
0.691
30
0.320
0.358
0.437
0.405
0.679
34
0.327
0.371
0.446
0.415
0.660
38
0.336
0.383
0.456
0.424
0.644
43
0.346
0.396
0.462
0.430
0.628
50
0.352
0.480
0.474
0.437
0.613
60
0.358
0.421
0.484
0.446
0.597
75
0.364
0.434
0.496
0.452
0.581
100
0.371
0.446
0.506
0.462
0.565
150
0.377
0.459
0.518
0.468
0.550
300
0.383
0.471
0.534
0.478
0.534
Rack
0.390
0.484
0.550
- These values assume a moderate temperature increase and some initial lubrication.
- With bevel gearing, divide the number of teeth by the cosine of the pitch angle and use the data in the table.
- For example, if a 20-deg PA bevel gear has 40 teeth and a pitch angle of 58 deg, 40 divided by the cosine of 58 deg = 40 ÷ 0.529919 ≈ 75, and Y = 0.434.
Table 2 Recommended Bending Stress Values for Plastic Gears
Plastic Type |
Recommended Stress | |||
Unfilled | Glass-Filled | |||
(lb/in2) | (MPa) | (lb/in2) | (MPa) | |
ABS | 3,000 | 20.68 | 6,000 | 41.37 |
Acetal | 5,000 | 34.47 | 7,000 | 48.26 |
Nylon | 6,000 | 41.37 | 12,000 | 82.74 |
Polycarbonate | 6,000 | 41.37 | 9,000 | 62.05 |
Polyester | 3,500 | 24.13 | 8,000 | 55.16 |
Polyurethane | 2,500 | 17.24 | ... | ... |
Table 3 Service Factors Plastic Gears
Load | 8-10 hr/day | 24 hr/day | Intermittent 3 hr/day |
Occasional 1/2 hr/day |
Steady | 1.00 | 1.25 | 0.80 | 0.50 |
Light Shock | 1.25 | 1.50 | 1.00 | 0.80 |
Medium Shock | 1.50 | 1.75 | 1.25 | 1.00 |
Heavy Shock | 1.75 | 2.00 | 1.50 | 1.25 |
Machinerys Handbook, 29th Edition
