Plate Loading over Central Rectangular Area
Flat Rectangular Plate Uniform Loading over Central Rectangular Area Stress Equation and Calculator.
NOTATION: The notation applies with the following modifications: a and b refer to plate dimensions, and when used as subscripts for stress, they refer to the stresses in directions parallel to the sides a and b, respectively. s is a bending stress which is positive when tensile on the bottom and compressive on the top if loadings are considered vertically downward.
Preview: Flat Rectangular Plate Stress and Deflection Load Applied at Center Calculator
Stress at CenterWhere Total Force/Load Applied:
Symbols used:
W = Total applied load or force (N, lbs)
t = plate thickness, (m, in)
a = plate length, (m, in)
b = plate width, (m, in)
a1 = plate length, (m, in)
b1 = plate width, (m, in)
σ max = maximum stress, (N/m2, lbs/in2)
Tables for β
