Pressure Vessel Calculator Python Script Application
Use this code to calculate the stresses in cylindrical pressure vessels. A calculator class, Vessel , and a GUI class, PV_GUI , are provided.
The calculator is intended for use with relatively simple pressure housings, without fittings, welds, or variations in material. For more complex vessels, the calculator may be used as a first step for the overall stress levels, to be followed by specific analysis of stress concentrations.
Given the dimensions of the pressure vessel, the material strength, and the applied pressure, the von Mises stresses in the wall are calculated. A safety factor is determined using both the maximum von Mises stress and the average stress between the inner and outer wall surface. The average stress is limited to a smaller proportion of the maximum allowable stress, which requires that vessels with thinner walls have larger margins of safety.
The allowable stress value should be chosen to represent the worst-case material strength while in use. By default, the tensile yield stress should be appropriate. If the service temperature is significantly higher than room temperature, the allowable stress should be reduced to compensate for any loss of strength in the material. Similarly, if the tensile strength and compressive strength are significantly different, choose the strength value corresponding to the load case (i.e. tensile for internal pressure, compressive for external pressure).
NOTE:
Refunds are not awarded after Python files have been downloaded - review your membership agreement for details.
Units (if utilized) utilized within calculators are either SI or Imperial (some enable both SI and Imperial) and member (you) are responsible for conversions. Ensure that you verify units utilized in excel application meet your requirements before downloading.
Download: Pressure Vessel Calculator Python Script Application
Output
Source
No requirements outside the Python Standard Library
Support:
- Engineers Edge has tested the basic functions and operation of this application using Python 3.11.9 and supporting modules.
- Supporting Windows application "Visual Studio Code".
- THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
- Thin Wall Pressure Vessel Hoop Stress
- Thin Wall Pressure Vessel Longitudinal Stress
- Blowdown Time in Unsteady Gas Flow Calculator and Equation . Blowdown is a planned or unplanned release of pressurized gas from storage or containment.
- Cylindrical Pressure Vessel Uniform Axial Load Equation and Calculator . Per. Roarks Formulas for Stress and Strain
- Cylindrical Pressure Vessel Uniform Radial Load Equation and Calculator . Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
- Cylindrical Pressure Vessel Uniform Internal or External Pressure, Ends Capped Equation and Calculator . Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
- Cylinder Linearly Varying Radial Pressure Stress and Deflection Equation and Calculator . Per. Roarks Formulas for Stress and Strain
- Cylinder Stress and Deflection by Own Weight Equation and Calculator . Per. Roarks Formulas for Stress and Strain
- Cylinder Stress and Deflection Uniform rotation, ω rad/sec about central axis Equation and Calculator . Per. Roarks Formulas for Stress and Strain
- Cone Cylinder Stress and Deflection Filled to Depth with Liquid Tangential Edge Support Equation and Calculator . Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels
- Cone Cylinder Stress and Deflection due to own weight at tangential top edge support Equation and Calculator. Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
- Cone Cylinder Stress and Deflection by Tangential loading only ; resultant load = P. Equation and Calculator. Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
- Truncated Cone Cylinder Stress and Deflection by Uniform loading on the horizontal projected area; tangential top edge support. Equation and Calculator. Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
- Bolt Torque Required for Sealing Flanges with Gaskets and Internal Pressure
- Spherical Cylinder Stress and Deflection by Uniform internal or external pressure, q force/unit area; tangential edge support Equation and Calculator . Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
- Spherical Cylinder Stress and Deflection Filled to depth d with liquid of density d force/unit volume; tangential edge support Equation and Calculator . Per. Roarks Formulas for Stress and Strain
