Pulley Friction and HP Brake Calculator
Pulley Friction Brake Equations and Calculator
In Fig. 1 a pulley revolves under the band and in the direction of the arrow, exerting a pull of T on the spring. The friction of the band on the rim of the pulley is (T - w), where w is the weight attached to one end of the band. Let the pulley make N r/min; then the work done per minute against friction by the rim of the pulley is 2πRN(T - w), and the horsepower absorbed by brake = 2πRN(T 2 w)/33,000.
Figure 1 Pulley revolving under the band
Marks Standard Handbook for Mechanical Engineers
- Design of Load Carrying Shaft With One Pulley & Supported by two Bearings
- Large and Small Diameter Lifting Pulley / Drum Equation and Calculator
- Two Lifting Lifting Pulley's Mechanical Advantage
- Multiple Pulley's Lifting Mechanical Advantage
- Pulley Differential Mechanical Advantage Equations
- Simple Hoist Pulley Equations
- Two Pulley Connecting Belt Design and Calculations
- Three Gears or Pulleys Force Calculations and Equations
- Length of Belt Traversing Three Pulleys
- Flat Belt Drive Design Calculator and Equations
