Rack and Pinion Drive Calculations
A rack and pinion is a type of linear actuator that comprises a circular gear (the pinion) engaging a linear gear (the rack). Together, they convert between rotational motion and linear motion. Rotating the pinion causes the rack to be driven in a line. Conversely, moving the rack linearly will cause the pinion to rotate. A rack-and-pinion drive can use both straight and helical gears.
Formulas for Determining the Tangential Force on the rack and pinion gears
Premium Membership required for calculator
Eq. 3
Eq. 4
a, rack acceleration is in m/s2
Fu, is in kN
Fuperm, is in kN
Futab = load carrying capability of rack pinion kN
m = mass in kg
v = speed in m/s
tb = seconds
g = gravity =9.81 m/s2
µ = constant
K
The Condition Fu < Fuperm Must be Fulfilled
Load factor KA
Drive | Uniform Loading |
Medium Shocks |
Heavy Shocks |
Uniform | - |
1.25 |
1.75 |
Light Shocks | 1.25 |
1.50 |
2.00 |
Medium Chocks | 1.50 |
1.75 |
2.25 |
Safety Coefficient SB
The safety coefficient should be allowed for according to experience (SB = 1.1 to 1.4).
Life-Time Factor fn
considering of the peripheral speed of the pinion and lubrication.
Lubrication |
Continuous |
Daily |
Monthly |
Peripheral Speed of Gearing |
m/sec |
m/min |
0.5 |
30 |
0.85 |
0.95 |
From 3 to 10 |
1.0 |
60 |
0.95 |
1.10 |
1.5 |
90 |
1.00 |
1.20 |
2.0 |
120 |
1.05 |
1.30 |
3.0 |
180 |
1.10 |
1.50 |
5.0 |
300 |
1.25 |
1.90 |
Linear Load Distribution Factor LKHß
The linear load distribution factor considers the contact stress, while it describes unintegrated load distribution over the tooth width (LKHß = √KHß).
LKHß = 1.1 for counter bearing, e.g. Torque Supporter
LKHß = 1.2 for preloaded bearings on the output shaft
LKHß = 1.5 for unpreloaded bearings on the output shaft
Kent's Mechanical Engineers Handbook, 1952
- Gear Type and Overview Spur Gears, Rack and Pinion Gears, Internal Ring Gears, Helical Gears, Helical rack Gears, Face Gears, Worm Gears, Double Enveloping Gears, Hypoid Gears, Straight Bevel Gears, Spiral Bevel Gears, Screw Gears
- Gears Spur and Helical Gears Calculation of Load Capacity
- Gear Tooth Strength Calculation and Equation Design guidelines for determining or estimating your required gear tooth strength.
- Gear Wear, Adhesion and Guidelines The amount of gear wear that is acceptable depends on the expected life, noise, and vibration of the gear units.
- Gear Wear and Abrasion Adhesive wear can be found between gear tooth surfaces during frictional contact.
- Gearbox Design and Application Overview Regardless of the initial conceptualization approach, engineering and design must identify the gearbox application, gear configurations / type and packaging requirements.
- Helical Gear and Pinion Calculator and Equations This calculator will determine the following design variables for a gear and pinion.
- Helical Plastic Gears Rated Design Hp, Operating Stress Equations and Calculator
- Helical Gears Shafts Parallel, Center Distance Exact Design Equations and Calculator
- Helical Gears Shafts Parallel, Center Distance Approximate Design Equations and Calculator
- Helical Gears Shafts at Right Angles Design Equations and Calculator
- Helix Gearing with Shafts at Any Angle, Center Distance Approximate Design Equations and Calculator
- Involute Spur Gear Generation Application and Calculator
- Numerical Analysis of Hybrid Spur Gears with Asymmetric Teeth: Stress and Dynamic Behavior
- Classification and Accuracy Tolerances for Coarse-Pitch Spur and Helical Master Gears An inspection master gear is used with selected fixtures to measure the variations in a manufactured gear.
- Spur Gear Generator with Download Spur Gear Generator is unitless: you may choose inches, cm or millimeters when importing your DXF file as you will have the same value for D/P as it is set above or as imported (SI or imperial units).
- Spur Gear and Assembly Builder Spur Gear and Assembly Builder calculates and models individual Spur Gears and Gear assembly. File down loads available with Premium Account.
- AGMA Gear Tooth Bending Stress Formula and Calculator Per standard ANSI/AGMA D04 Fundamental Rating Factors and Calculation Methods for Involute Spur and Helical Gear Teeth:
- AGMA Major metallurgical factors affecting the allowable contact stress number , s ac , and allowable bending stress number
- Gear Design Handbook Premium Membership Required
- AGMA Spur Gear Profile Calculator Spread Sheet - Three excel calculation sheets that include the following input data/variables, calculated data and chart graphics.
- AGMA Worm and Spur Gear Design Equations and Calculators Worm gear sets are generally rated by their capacity to handle a particular level of input power, output power, or allowable torque at a particular speed for the input or output shaft.
