Reaction and Deflection Case 5N Elastic Frame Roark's Formulas for Stress and Strain Formulas and Calc
Reaction and deflection formulas for in-plane loading of elastic frame with mounting ends fixed and Concentrated Angular Displacement on the Right Vertical Member Frame formulas and calculator. Roark's Formulas for Stress and Strain, Seventh Edition, Table 8.2 reference loading number 5N.
The formulas given assume the frames to have rigid corners; however, corrections can be made easily once the rigidity of a given corner design is known by making use of the concentrated angular displacement loading with the displacement positioned at the corner.
Loading Configuration
Deformation equations:
Loading terms for Concentrated moment on the right vertical member frame member:
Where used:
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
