Rectangular Pier Spread Footing Analysis Calculator
This calculator will analysis the rigid rectangular spread footings with up to 8 total piers, and for either uniaxial or biaxial resultant eccentricities. Overturning sliding, and uplift stability checks are made when applicable, and resulting gross soil bearing pressures at the four (4) corners of the footing are calculated. The maximum net soil bearing pressure is also determined.
Notes:
Calculations assumes that the spread footing is in fact "rigid", so that the bearing pressure is distributed linearly on a homogeneous soil. (Note: the actual footing is generally not "rigid", nor is the pressure beaneth it distributed linearly. However, it has been found that solutions using the assumed "rigid" concept are adequate and generally result in a conservative design.)
A specified permissible value for the factor of safety against overturning. However, a minimum value of 1.5 to 2.0 is suggested, based upon the particular conditions.
www.engineersedge.com
Advertising | Contact
Privacy Policy
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
