Rectangular Hollow Tube Section Properties Calculator
Rectangular Hollow Tube Sections Hot-Finished per BS EN 10210-2 Section Properties Calculator
The following design data to Eurocode 3 (in accordance with the UK National Annex):
Section properties:
Universal Rectangular Hollow Section
(1) For local buckling calculation cw = h - 3t and cf = b - 3t
BS EN 10210-2
Selected data from Steel for Life Blue Book
- Square Hollow Tube Hot-Finished Universal Sections Calculator
- Circular Hollow Tube Universal Section Properties Calculator
- Universal Tees (T) Split from UC Section Calculator
- Universal Tees Split From Universal Beams Calculator
- Universal Back to Back Unequal L Angles Section Properties Calculator
- Universal Back to Back Equal L Section Properties Calculator
- Universal Unequal leg Angles (L) Section Properties Calculator
- Universal Equal leg Angles L Section Properties Calculator
- Universal Parallel Flange Channels Properties Calculator
- Universal Bearing Piles Section Properties Calculator
- Universal Columns Section Properties Calculator
- Universal Narrow Beams Dimension Data
- Structural Steel AISC Shapes Properties Viewer
- AISC, ASTM Wide Flange #1 Steel
- AISC, ASTM Wide Flange #2 Steel
- AISC, ASTM S Narrow Flange I Beam Steel
- Steel Section Properties Chart Narrow I-Beam BS 4-1 | EN 1993-1-1
- Steel Section Properties Chart Wide I-Beam BS 4-1 | EN 1993-1-1
- Indian Standard Flange Beams per. IS 808
- Properties of Rolled-Steel Shapes I-Beam Sections, Standard GOST 8239-72
