Rectangular Sections Cold-Formed Section Properties Calculator
Rectangular Tube Sections Cold-Formed per BS EN 10219-2 Section Properties Calculator
The following design data in accordance with the Eurocode 3 UK National Annex:
Section properties:
Eurocode 3 UK Rectangular Section
(1) For local buckling calculation cw = h - 3t and cf = b - 3t
BS EN 10219-2
- Square Hollow Tube Hot-Finished Section Properties Calculator
- Circular Tube Sections Cold-Formed Section Properties Calculator
- Elliptical Hollow Tube Section Properties Calculator
- Circular Hollow Tube Universal Section Properties Calculator
- Universal Tees (T) Split from UC Section Calculator
- Universal Tees Split From Universal Beams Calculator
- Universal Back to Back Unequal L Angles Section Properties Calculator
- Universal Back to Back Equal L Section Properties Calculator
- Universal Unequal leg Angles (L) Section Properties Calculator
- Universal Equal leg Angles L Section Properties Calculator
- Universal Parallel Flange Channels Properties Calculator
- Universal Bearing Piles Section Properties Calculator
- Universal Columns Section Properties Calculator
- Universal Narrow Beams Dimension Data
- Structural Steel AISC Shapes Properties Viewer
- AISC, ASTM Wide Flange #1 Steel
- AISC, ASTM Wide Flange #2 Steel
- AISC, ASTM S Narrow Flange I Beam Steel
- Steel Section Properties Chart Narrow I-Beam BS 4-1 | EN 1993-1-1
- Steel Section Properties Chart Wide I-Beam BS 4-1 | EN 1993-1-1
- Indian Standard Flange Beams per. IS 808
- Properties of Rolled-Steel Shapes I-Beam Sections, Standard GOST 8239-72
