Reinforced Concrete Beam Design per. Eurocode 2
EN 1992 Eurocode 2 applies to the design of buildings and other civil engineering works in plain, reinforced and prestressed concrete. It complies with the principles and requirements for the safety and serviceability of structures, the basis of their design and verification that are given in EN 1990: Basis of structural design. EN Eurocode 2 is concerned with the requirements for resistance, serviceability, durability and fire resistance of concrete structures.
EN 1992-1-1 Eurocode 2: Design of concrete structures - Part 1-1: General rules and rules for buildings
EN 1992-1-2 Eurocode 2: Design of concrete structures - Part 1-2: General rules - Structural fire design
EN 1992-2 Eurocode 2: Design of concrete structures - Part 2: Concrete bridges - Design and detailing rules
EN 1992-3 Eurocode 2: Design of concrete structures - Part 3: Liquid retaining and containment structures
Precision:
Input - Insert the dimension of the beam cross-section and span length, loads with their respective safety factors and material properties of the concrete and the reinforcement steel.
Rc beam section
Section
Width (b) m
Depth (h) m
Length (l) m
Concrete cover m
Load
Dead load kN/m
Live load kN/m
Moment redistribution
Material
Concrete grade
Flexural and shear rebar grade
Flexural and shear rebar size
Number of stirrup leg
Output results - This will design a reinforced concrete beam for flexure and shear in the tables below from the design input data in the table above.
This application Requires Premium Membership to execute calculations
Flexure design values
Beam design
Design load
kN/m
Design moment
kN-m
Effective depth (d)
m
Effective depth (d2)
m
K value
K' value
Tension steel area (As1)
mm2
Compression steel area (As2)
mm2
No of reinf. bar in tension
No of reinf. bar in compression
Shear design values
Design shear stress (VED)
MPa
Concrete strut capacity (vRd)
MPa
MPa
Minimum angle of strut (θ)
Area per spacing (As/s)
mm
Shear reinforcement (Asw)
mm2
Spacing for shear reinforcement c/c
mm
Reinforced concrete Beam Design Equations used in calculator
Browser does not support this operation
Alazar Woldeyohannes
Master's program in Structural Engineering in the School of Mechanical, Aerospace and Civil Engineering
University of Manchester
Email available on request
