Relative Density Degrees API and lb/gal. Calculator
Relative Density, Degrees API and lb/gal. Calculator
Density of a body is its mass per unit volume. With SI units densities are in kilograms per cubic meter. However, giving densities in grams per cubic centimeter has been common. With the USCS, densities are given in pounds per mass cubic foot
Relative Densities at 60°/60°F Corresponding to Degrees API and Weights per U.S. Gallon at 60°F
Note: The weights from the table calculator are in air at 60°F with humidity 50 percent and pressure 760 mm.
Calculated from the formula:
where:
RD = Relative density
APIdeg = Degrees API
Marks Standard Handbook for Mechanical Engineers
- Density of Common Engineering Materials
- Air Density Table and Specific Weight Table, Equations and Calculator
- Water Vapor Density
- Densities of Metals and Elements Table
- Density Equation and Review
- Air Density Equations and Calculator
- Density of Various Solids Tables
- Water - Density Viscosity Specific Weight
- Relative Humidity and Weight per Cubic Foot Volume of Air
- Specific Weight Formula and Review
- Specific Gravity materials, gasses and liquids Table Chart and Equation
- Density of Wood Equation and Calculator
- Speed of Sound in Various Liquids and Solids
- Manometer Calculator and Equations
- Properties of Fluids - Fluid Flow Hydraulic and Pneumatic
- Kinematic Viscosity Equation Application
