Rolling Piston Compressor Operation and Displacement Calculator
Rolling-piston, or fixed-vane, rotary compressors are used in air-conditioning units in capacities up to about 30 kBtu/h and refrigerators up to 2.5 hp. This type of compressor uses a roller mounted on the eccentric of a shaft with a single vane or blade suitably positioned in the nonrotating cylindrical housing, generally called the cylinder block. The blade reciprocates in a slot machined in the cylinder block. This reciprocating motion is caused by the eccentrically moving roller.
Figure 1 - Fixed-Vane, Rolling-Piston Rotary Compressor
(Republished with premission from ASHRAE)
Geometrical displacement for this compressor can be calculated from the following equation:
Vd = π H ( D2 - d2 ) / 4
where
Vd = displacement (in3, mm3),
H = cylinder block height (in, mm),
D = cylinder diameter (in, mm),
d = roller diameter (in, mm)
Typical Rolling-Piston Compressor Performance
Compressor speed | 3450 rpm |
Refrigerant |
R-22 |
Condensing temperature |
130°F |
Liquid refrigerant temperature |
115°F |
Evaporator temperature |
45°F |
Suction pressure |
90.7 psia |
Suction gas temperature |
65°F |
Evaporator capacity |
12,000 Btu/h |
Energy efficiency ratio |
11.0 Btu/W·h |
Coefficient of performance |
3.22 |
Input power | 1090 W |
Related White Papers
Motion Analysis of Rolling Piston in Rotary Compressor (Free Membership required)
Source
- ASHRAE HVAC Handbook, 2016
- Motion Analysis of Rolling Piston in Rotary Compressor T. Yanagisawa T. Shimizu I. Chu K. Ishijima Purdue University
Related resources
- Air Gas Compressors Review Air compressor (gas compressor) is a machine that pressurizes or compresses air.
- Multi Stage Air Compressor Multi Stage Air Compressor design equations
- Reciprocating Air Compressor Reciprocating Type Air Compressors design equations
- Roots Type Air Compressor Roots Type Air Compressor design equations
- Compressed Air Dryers Review Compressed air dryers are used to remove water and other contaminants from compressed air
- Vacuum Pump Filter Review Vacuum pump filters (intake & exhaust) are designed to prevent dust and particulate matter from entering or exiting vacuum pump
- Vane Type Air Compressor Review and Design Equations Vane Type Air Compressor design equations
