Sealing Flanges with Gaskets Bolt Torque Requirements Calculator
Pressure Vessel Pipes Design Engineering ASME
Bolt Torque Required for Sealing Flanges with Gaskets and Internal Pressure
Preview Bolt Torque Required for Sealing Flanges with Gaskets Calculator (Premium Membership required for calculator)
Equivalent Pressure
Hydrostatic end force, H, lb
Total joint-contact-surface compression load, Hp, lb
Eq. 3
Minimum required bolt load for gasket seating, Wm2, lb.
Eq. 4
Actual joint area contact for gasket, Ag, in2
Eq. 5
Decreasing compression force in gasket, ΔF, lb
Eq. 6
Initial required tightening force (tension), Fbo, lb.
Eq. 7
Total tightening force required to seal joint, W, lb.
Eq. 8
W = greater of Fbo or Wm2
Required torque, T, ft-lb
Eq. 9
Pe = equivalent pressure including external loads, psi
M = external bending moment, in.-lb
G = avaerage diameter at location of gasket load reaction, in.
Pr =
radial load, lb
P =
internal pressure, psi
b = effective gasket seating width (diameter), in.
m = gasket factor
Wm2 =
required bolt load, gasket seating, lb
y = gasket unit seating load, psi
Ag =
actual joint-contact area of gasket, in.2
ΔF = Decreasing compression force in gasket, lb
H = total hydrostatic end force, lb
Ab = cross-sectional area of bolts, in.2
Eb =
modulus of elasticity of bolting material at temperature, psi
tg =
thickness of gasket, in.
lb =
Hp =
total joint-contact surface compression load, lb
Fbo =
= initial tightening force, Ib
K = total friction factor between bolt / nut and nut / flange face
W =
total tightening force, lb
dm =
pitch diameter of threads, in
n =
number of bolts
Friction factor (typical)
Lubricated = 0.075-0.15
Nonlubricated = 0.15-0.25
Figure1 Flange and joint details.
Table 1, Torque Required in ft-lb to Produce the Following Bolt Stress
Bolt Size | 15 ksi | 30 ksi | 45 ksi | 60 ksi |
1/2-13 |
15 | 30 | 45 | 60 |
5/8-11 |
30 | 60 | 90 | 120 |
3/4-10 | 50 | 100 | 150 | 200 |
7/8-9 | 80 | 160 | 240 | 320 |
1-8 | 123 | 245 | 368 | 490 |
1-1/8 - 8 | 195 | 390 | 533 | 710 |
1-1/4 - 8 | 273 | 500 | 750 | 1000 |
1-3/8 - 8 | 365 | 680 | 1020 | 1360 |
1-1/2 - 8 | 437 | 800 | 1200 | 1600 |
1-5/8 - 8 | 600 | 110 | 1650 | 2200 |
1-3/4 - 8 | 775 | 1500 | 2250 | 3000 |
1-7/8 - 8 | 1050 | 2000 | 3000 | 400 |
2-8 | 1125 | 2200 | 3300 | 4400 |
2-1/4 - 8 | - | 3180 | 4770 | 6360 |
2-1/2 = 8 | - | 4400 | 6600 | 8800 |
2-3/4 - 8 | - | 5920 | 8880 | 11840 |
3 - 8 | - | 7720 | 11580 | 15440 |
Notes:
1. Bolted joints in high-pressure systems require an initial
preload to prevent the joint from leaking. The loads
which tend to open the joint are:
a. Internal pressure.
b. Thermal bending moment.
c. Dead load bending moment.
2. Either stud tensioners or torque wrenches are used for
prestressing bolts to the required stress for gasket seating.
Stud tensioners are by far the most accurate. Stud
tension achieved by torquing the nut is affected by
many variables and may vary from 10% to 100% of
calculated values. The following are the major variables
affecting tension achieved by torquing:
a. Class of fit of nut and stud.
b. Burrs.
c. Lubrication.
d. Grit, chips, and dirt in threads of bolts or nuts.
e. Nicks.
f. The relative condition of the seating surface on the
3. Adequate lubrication should be used. Nonlubricated
bolting has an efficiency of about 50% of a well-lubricated
bolt. For standard applications, a heavy graphite
and oil mixture works well. For high temperature service
(500'F to 1000"F), a high temperature thread
compound may be used.
4. The stiffness of the bolt is only 1/3 to 1/5 that of the
joint. Thus, for an equal change in deformation, the
change of the load in the bolt must be only 1/3 to 1/5
of the change in the load of the joint.
5. Joints almost always relax after they have first
been tightened. Relaxation of 10% to 20% of the initial preload is not uncommon. Thus an additional preload
of quantity F is required to compensate for this “relaxing”
of the joint.
- Gasket Compression and Fastener Spacing Design Equation and Calculator
- Bolt Torque for Gasket Contact Stress per. ASME PCC-1
- Gasket Compression Stops Application and Design
- Specification for Rubber Gaskets
- Fastener and Screw Torque Design and Equation and Calculator
- Torque Wrench Calculator for Extended Adapter with Formulas
- Torque Wrench Adapter for Reduced Arm Equation and Calculation
- Bolt Torque, Axial Clamp Force, Bolt Diameter Calculator
- Bolt Torque and Clamping Force Formulas and Calculator per. JIS B 1083
- Torque Table Standard Bolt Sizes SAE
Pressure Design Manual, Third Edition, Dennis Moss 2004
