Area Moment of Inertia Section Properties: Triangle Calculator
Section Properties Equations and Calculators
Area Moment of Inertia Section Properties: Triangle Section Properties Calculator
Area Moment of Inertia Section Properties of Triangle Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Triangular Section
Variables
Inputs Inch mm
Length h (in, mm) =
Length b (in, mm) =
Calculated Properties
Area Moment of Inertia Section Ix (in4, mm4) =
Area Moment of Inertia Section Ix' (in4, mm4) =
Area Moment of Inertia Section Iy (in4, mm4) =
Area Moment of Inertia Section Iy' (in4, mm4) =
Distance x (in, mm) =
Distance y (in, mm) =
Area (Unit2) =
