Area Moment of Inertia Section Properties: Parabolic Spandrel Calculator
Section Properties Equations and Calculators
Area Moment of Inertia Section Properties: Parabolic Spandrel Section Properties Calculator
Area Moment of Inertia Section Properties of Parabolic Spandrel Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Description |
Equation
Distance to neutral axis y' (in, mm) = | x' h / b2 |
Distance to neutral axis y (in, mm) = | 3h / 5 |
Distance to neutral axis x (in, mm) = |
3b / 8 |
Area A (in2, mm2) = |
2bh / 3 |
