Area Moment of Inertia Section Properties: Rectangle Tube Calculator
Engineering Metals and Materials | Strength of Materials
Area Moment of Inertia Section Properties of Rectangle Tube Calculator Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Description |
Equation |
Area Moment of Inertia Section Properties = I |
Section Modulus = Z = I/y |
Radius of Gyration |
A = area |
A = db - hk |
y = Distance to neutral axis |
y = d/2 |
