Area Moment of Inertia Section Properties: Hexagon Calculator
Section Properties Menu
Engineering Metals and Materials
Strength of Materials
Area Moment of Inertia Section Properties: Octagon Calculator
Area Moment of Inertia Section Properties of Octagon Feature Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Description
Equation
Area Moment of Inertia Section Properties = I
Moment of Inertia
Section Modulus = Z = I/y
Section Modulus
Radius of Gyration
Radius of Gyration
A = area
Area
y = Distance to neutral axis
d/2
Note: Units are either inches (left column) or mm (right Column).
