Area Moment of Inertia Section Properties : Triangle at Edge Calculator
Strength of Materials
Area Moment of Inertia Section Properties: Triangle Edge Calculator
Area Moment of Inertia Section Properties of Triangle at Edge Feature Calculator and Equations. This engineering calculator will determine the section modulus for the given cross-section. This engineering data is often used in the design of structural beams or structural flexural members.
Description
Equation
Area Moment of Inertia = I
Moment of Inertia
Section Modulus = Z = I/y
Section Modulus
Radius of Gyration
Radius of Gyration
A = area
1/2(db)
y = Distance to neutral axis
d
Variables
Inputs:
"b" (Base)
"d" (Height)
Properties:
Area Moment of Inertia (Units4)
Section Modulus (Units3)
Radius of Gyration (Units)
Extreme Point (Units)
Area (Units2)
