Shear Webs with Beads Stress Formula and Calculator
Shear Webs with Beads Critical Shear Stress Equation and Calculator
Beaded panels are one type of non-bucking shear webs. Stiffeners must be added at load points to prevent premature collapse under loading. Since the collapsing stress is only slightly higher than the buckling stress, the buckling stress should be considered the ultimate allowable .
The critical shear stress τcr for a beaded web can be expressed as:
Shear Buckling Constant, Figure 2
F2= H3 ( h / d )
Eq. 3
Panel Aspect Ratio, Figure 3
F3 = a / h
E = Modulus of elasticity lbs/in2
t = thickness, in
h = plate width, in
a = plate length, in
H = bead height, in
d = bead spacing, in
µ = poisson's ratio
Ks = Simply supported flat sheet - curve "2", shear buckling constant based on a/b from figure 2
Kl
= Beaded-web shear buckling coefficient obtained from figure 3
Figure 1, Simply Supported Beam with Mass at Center Natural Frequency
Figure 2, Beaded Web Shear Buckling Constant
Figure 3, Shear buckling Coefficient, Ks
Source
Bell Helicopter Structural Design Manual, 1977
- Beam with Ends Free Angular Natural Frequency Equations and Calculator
- Circular Plate Concentrated Load Edges Fixed Support Equation and Calculator Circular Plate Concentrated Load Edges fixed Supported Equation and Calculator
- Circular Plate Concentrated Load Floating Equation and Calculator Circular Plate Concentrated Load Floating Equation and Calculator
- Circular plate, uniform load, edges clamped equation and calculator Circular flat plates subject to concentrated or distributed loads (pressure) with the edge either clamped or supported.
- Circular plate, uniform load, edges simply supported equation and calculator Maximum stress and deflection for circular flat plates subject to concentrated or distributed loads (pressure) with the edge either clamped or supported.
- Flat Rectangular Plate with All Edges Simply Supported Stress and Deflection with straight boundaries and constant thickness Equation and Calculator Roark's Stress Strain
- Flat Rectangular Plate with All Edges Simply Supported Stress and Deflection with circular Load applied at center Equation and Calculator
- Flat Rectangular Uniform over entire plate plus uniform over entire plate plus uniform tension
- Flat Rectangular Plate; Three Edges Simply Supported, one Edge (b) Free Stress and Deflection With Uniformly increasing along the a side Equation and Calculator
- Flat Rectangular Plate; Three Edges Simply Supported, one long Edge Fixed Stress and Deflection With Uniform Loading over entire plate Equation and Calculator
- Flat Rectangular Plate; one edge fixed, opposite edge free, remaining edges simply supported Uniform loading over entire plate
- Flat Rectangular Plate; one edge fixed, opposite edge free, remaining edges simply supported loading
- Parallelogram plate (skew slab) all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator
- Concentrated load at center of Plate, clamped edges (empirical) equation and calculator
