Pressure Vessel Wall Thickness of Longitudinal Shells With Internal Pressure Applied Calculator
Pressure Vessel Design and Calculators
This calculator determines the thickness of a circumferential shell with an internal pressure applied: Typical applications are propane tanks, compressed air storage tanks etc.
The "Joint Efficiency" reflects your confidence in the welded seam areas of the as-manufactured pressure vessel.
Note: When Thickness does not exceed one-half of the inside radius, or P does not exceed 1.25SE, use the following calculator.
